Hi all. My '97 Firebird T/A's BCM has an intermittant failure in that the radio and power windows will lose power. I've removed the BCM from its holder and disconnected the J1 and J3 connectors. With the J2 connector (middle one, black) still connected and the key in the ACCY position the radio will work. But if I just apply some pressure to that connector I can get it to turn off or on at will so I'm pretty sure the problem is either in the connector or on the board at that spot.
Looking at the board I can't see any obvious solder cracks. Probing with a multimeter on the BCM I get about 1.1 kohms between pins D and A(gnd I think). Also pins D and C appear to be shorted (0 ohms). I don't have a schematic for the BCM circuit (found a '96 one but the '97 BCM is different).
I can get a used BCM (matched to my key resistor value) for about $100 off of eBay (from Trans Am Creations) but I'm not yet sure it's the board and not the connector going to the board. I inspected the metripak briefly and it appeared all 6 wires were going into the connector solidly.
Any clues?
Any clues?
