I am having trouble with my windshied fluid sprayers, my drivers side sprays good it sprays clear over top the car. My passenger side sprayer jus trikkles out it has no pressure behind it at all. MY car is a 2000 firebird. Anyone know how to fix this?
On the 94 you have to pull the big black plastic cowl panels (left and right) by removing the push-in rivets that hold the cover panel to the cowl. The push-in rivets are reached by removing the big rubber hood seal gasket from the cowl panel. There are about a half-dozen rivets. The hoses tee off the supply line under the panel. I would assume the newer models are similar, but don't know for sure.Fred
Had the exact same problem. Personally, I used a push pin and ran hydrogen peroxide through the system and cleaned it out great. just be careful if you don't want to take the entire cowl apart, tug the wrong tubing and it'l pull apart and youll be stuck tearing the cowl out-Alex
ZO6 wheels (clones)
With questionable guts:
Forged bottom end
pacesetter longtubes
K&N RAM air from 96 ws6
96? ws6 hood
96? ws6 spoiler
full emissions delete
Edelbrock IAS shocks
Originally posted by InjuneerOn the 94 you have to pull the big black plastic cowl panels (left and right) by removing the push-in rivets that hold the cover panel to the cowl. The push-in rivets are reached by removing the big rubber hood seal gasket from the cowl panel. There are about a half-dozen rivets. The hoses tee off the supply line under the panel. I would assume the newer models are similar, but don't know for sure.1988 5.0 TBI Camaro 700R4 Transmission
