I'm not sure if my '94 has high/low speed fans, but I think it's an earlier model of 1994.  The fans are programmed to go on at 187/187 in LT1 edit and the stat is a 160 SLP.  Here is the behavior:
- When driving on the freeway, the coolant temp will stay pretty low, roughly 3/4 between the 160 and first hash.
- When driving in the city without A/C, the coolant will hit around 191 but sometimes dip to 187.
- When driving in the city with the A/C going, the coolant will hit over 210 after a while. I'm too afraid to let it continue sitting though. I usually turn the A/C on during hot days, so I'm not sure if it's because the A/C changes the fan settings or turns off the secondary fan, or if it's just the sheer heat outside and it needing a flush.
Does anyone know if turning the A/C on changes the fans, if both already going full blast? Thanks in advance.
