I'm in the process of converting all four brakes. The front - C5 calipers.
The rear - rebuild the original calipers. I've managed to get all of the new seals and such back together. However, I'm stuck with the parking brake spring. How do I re-engage the tangs? I tried several different prying methods, using a large screwdriver to compress it, but after nearly impaling myself, I thought it was time to ask for help.
Is there a preferred method? i.e. on the car or off the car, lying on the ground, etc.
Because of the way the spring-tang is hooked, you can only engage one side first. My buddy thinks perhaps it would be easier if I removed the parking brake cable, but if I do, I doubt I can reattach it to the hooked arm.
I'm stuck...
I'm stuck...
not to stab yourself, If the screwdriver slips, your hand will probably take the hit. I would highly recommend a good pair of leather gloves...just in case.
