Driver's side power window?
  • Driver's side power window?
    New driver's side window switch.
    Passenger window works great from either driver's or passenger's switch.
    When trying operate the driver's window, all that happens is a "click" from somewhere above the brake pedal. No window movement.
    Had the window motor out & checked it w/ 12v. Runs freely in either direction.
    What is the cause of the non-operable driver's window?
    It could be the switch itself. But you say you are hearing a click sound?
    The window motors can run without load, even if acting faulty. That's because they have a thermal cutoff, either a copper strip or thermal sensor. When these strips or sensors wear, they fail to supply enough current to raise or lower the glass. You may need new motors, after all.
    I just replaced both of my motors and everything's fine now.
    You should try getting a new switch first; they're realatively cheap. If that doesn't work, try checking the plug to the motors to see if proper voltage is supplied.
    Good luck.
