89 IROC 350 TPI, idle surging up and down after coming to a stop light. Only does it when engine is warm (not necessarily all the way warmed up). That was the only symptom for last few mos...now it is starting to shake a bit at idle, and the exhaust note sounds different, louder not as smooth. you can also feel it surging a little bit when cruising in 3rd/4th gear around 45 mph. Also a strange sour fuel/unburned fuel smell after you shut it down. When you get on it still has good power though.
Checked ECM, no stored codes, no ck eng light. Any ideas?
