I haven't seen any projectors that do both low and high beam. Since you have a 2 headlight system instead of a 4 I don't know of a way to use projectors unless you give up your high beams. But I have to say that since I put in the projectors in my low beams I have not used my high beams. I haven't found a need to use them. I have seen a projector low beam that will fit your car. You would probably be very happy with them and never miss your high beams but there is something just fundamentally wrong with changing the lights to something that looses an option like high beams. That would be hard to do. The H4 Bi-xeonon might be the best way.
Good replacement fog lights?
Thanks so something like this would work? Anybody has any experiences with this outfit?
http://www.ledgauges.com/sealedbeam.html
Ouch looking at the $$$$
That lens pattern its not NHTSA approved...
You may want to ask here where i bought my Hella H4 Euro lights
Contact Ken Beard
http://www.rallylights.com/detail.aspx?ID=4252
Another options:
http://www.rallylights.com/SearchRes...CategoryID=364
Then You could purchase the HID Hi/Lo sytem
regards
dochidalgo97 A4 Pontiac Firebird Trans am with $everal mod$
My 08 GMC Acadia has HI/LOW projectors as well as 09 and 10. The 07 Acadia had a 4 projector beam style with the low beam running the DRL's. 08's and up are only the 2 projectors running both HI/LOW. The DRL's on 08's and up are ran by a very low wattage bulb in a projector housing but without the projector lense. GM switched this due to HID burnout from the Lows running the DRLs all day! LOL!!! Stupid design though.Originally posted by Jeff_in_AtlI haven't seen any projectors that do both low and high beam. Since you have a 2 headlight system instead of a 4 I don't know of a way to use projectors unless you give up your high beams.
Well I have not given up to get better lights on my TA. The fogs I put in still are working well and worth their money.
The headlights were still crummy. So I bought a cheap set of projector lenses on Ebay with H4 bulbs. Had to modify the connector by making two adapter wire pieces. They were somewhat better but still crummy, specially now when it get dark earlier.
Would any if these cheaper Bi-xenon kits work with my H4 projector lenses and if so what wattage should I get? I will stick with the 4300k's regarding color.
This one here for example
http://www.ebay.com/itm/Bi-xenon-HID...item2a137eb6e8
Thanks Rene97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
