1994 3.4L engine wiring diagram needed
  • 1994 3.4L engine wiring diagram needed
    Chilton's is some kind of messed up. Ex. Shows dk blue wire on pin 20 of the PCM as a ground but the wire is shown as going to the knock sensor.
    Anyone have a factory service diagram?
    Well, there are 3 connectors. Pin 20 of connector C (blue) is the dark blue wire for the knock sensor.
      The Chiltons has incorrect labels in the box representing the PCM. Right under C20 (which is labeled as "GROUND"), for example, the six injector wires are incorrectly labled as "A/C Status"; "Ignition Input"; "-blank-"; "Pressure Control Sol (HI)"; "Pressure Control Sol (LO)"; "-blank-". Just ignore the labels. The pin designations, wire colors and wire routing appear correct.
        On a Fiero forum one can find links to download things like year specific factory service manuals ( http://www.fieronews.net/fusion/downloads.php ) and Haynes manuals (http://www.fieronews.net/fusion/Down...ads/haynes.pdf ) for Fieros.
        Do we have similar links for Firebirds anywhere?
