Hi. Does anyone know (particularly those familiar with 3.8s) if I can use the longer oil filter specified for the 4.3 L? I believe the treads and diameter are the same, and that it's just longer. There is plenty of room in the V6 F-bodies for a longer filter. If it would work, I'd like to use the longer one made for the truck (4.3) engine and put a full 5 qts instead of using the Dixie-cup sized filter with 4.5 qts.
Using a bigger oil filter
While I don't know if the filter in question is the same thread, I can talk about using a bigger filter.
I've been using the truck version of the LT1 filter on my car for over 10 years. Like you, I grew tired of having a half quart of oil left all the time. Additionally, the biggest benefit is increased surface area to filter the oil. Sure, a little more oil is a good thing, but the added flow potential as the filter becomes old is the greatest benefit.
I say - go for it. Just make sure the threads are the same, and the filter will physically fit into the space without hitting anything.Al 96 Ram Air T/A
Originally posted by Al 96 Ram Air T/AAdditionally, the biggest benefit is increased surface area to filter the oil. Sure, a little more oil is a good thing, but the added flow potential as the filter becomes old is the greatest benefit.
Thanks, Al. I can still get away with returning it most likely if the treads don't match. More surface area = more filter to hold the dirt and better flow. As for fitting, there must be ten inches of free space there that an LS1 would otherwise occupy.Matt
1998 Firebird 5-speed
2005 Pontiac Sunfire 4-door 5-speed
just make sure they have the same "workings" some filters have a anti-drain back valve and/or a pressure relief valve built into them. if you got a filter book its easy to look up the stuff2009 Honda Civic EX- the daily beater
Originally posted by Trash manjust make sure they have the same "workings" some filters have a anti-drain back valve and/or a pressure relief valve built into them. if you got a filter book its easy to look up the stuff
ThanksMatt
Moroso offers SBC filters up to 2 quarts. They provide the thread specs, so you can check to see if they match your V6. All of the SBC filters have an anti-drainback valve and a pressure bypass valve.
http://www.moroso.com/catalog/catego...?catcode=20002Fred
Thank you, everyone. Moroso racing filters look great but it may be a little overkill for me. I did some more reading and found that it's somewhat common to use the 4.3 filter for the 3.8. I got myself a free M1-201 and going to use it one the next change. Should be good.
Thanks.Matt
mobil1's m101 and m201 are the same - just longer (higher capacity). lots of the v6 guys use it. a turbo v6 in atlanta uses k&n's...not sure the code, but it's exactly the same as mobil1 filters, except a couple bucks cheaper.
ac delco pf52 the bigger one, I have a few for the baby camaro with the 3.893 t/a A4 3.23s
99 Alfa Romeo 166 3.0 v6, red
97 3.8 v6 A4 camaro, hardtop
00 audi a6 4.2 40 valve v8
Originally posted by Christopherrrmobil1's m101 and m201 are the same - just longer (higher capacity). lots of the v6 guys use it. a turbo v6 in atlanta uses k&n's...not sure the code, but it's exactly the same as mobil1 filters, except a couple bucks cheaper.
Originally posted by Trans Amac delco pf52 the bigger one, I have a few for the baby camaro with the 3.8
Thanks everyoneMatt
