the alternator on the 95 t/a is making a noise that sounded like a lifter or something in the engine, metallic knock . At some point , probably when the underdrive pulley was installed , the alternator bracket got broken, the aluminium part that bolts to the front of the engine. only a little part of it where the bolt goes into the alternator , but it was enough to change the alternator position slightly and over time seems like the bearings in the alternator gave up.
its the higher amp alternator according to the rpo.
Is it possible to replace just the bearings? apart from the noise it works ok
