Ok, I warm up the engine before changing the oil. 45-60 psi depending on RPMs.
Let the oil drain for about 30 minutes while I cool off inside my house in the A/C.
Reinstall drain plug, add 4 quarts of oil, check dipstick, reads FULL. Did not change the Fram oil filter
Start engine, no oil pressure. Idle for about 30 seconds and the gauge still reads 0.
Now what? Did the pump lose it's prime? Do I need to remove the oil pan & replace the pump? Or something else?
It's a 94 3.4 L V-6 with 152K miles. Oil has been changed every 3k miles since new.
