Hey everyone, I've been having a problem with my rear brake calipers, mostly the passenger side, but the drivers side is starting to bark at me a little too.
Basically, I'm getting a scraping metal on metal from the passenger side rear on a quick right hand turn, it sounds like I'm dragging a rotor on the pavement with a rope. This happened BEFORE AND AFTER new pads and rotors and did not change, if anything has gotten worse after greasing the caliper guides.
There is no noise while I am applying braking force in a turn or while going straight. Front brakes are totally fine, 0 problems.
It also looks as though my pads are not putting as much pressure towards the inner circumference of the rotors as well.
The entire brake system is either original or OEM replacement.
Thanks again,
Thanks again,
The other possibility is a bent backing plate that the caliper mount bolts to, difficult to tell still...
