So I failed smog...again. The only difference between this and last time is my tune and a new O2 sensor. Here's the differences between the old and new tune:
CAT OverTemp
Target AFR
new = 14.7, old = 12.2
Minimum Coolant temp
new = 151.2, old = 85.25
Fuel
Injector size
new = 34.963, old = 39.841
Open loop afr vs load vs cool temp
new = 9.5, old = 8.3
new = 15.8, old = 14.6
(whole chart changed but that's just an example of the # differences)
Chassis
Hysteresis
new = 7, old = 5
So, will these items hurt the smog numbers?
Here are the new smog numbers (btw, the smog nazis changed the max limits so now if I get to my previous #s, I'll barely pass, unlike before, when I passed easily)
15 mph: HC: 68 (max 58), CO% 0.20 (max 0.34), NO 693 (max 483), CO2% 14.01, O2% 1.10.
25 mph: HC: 63 (max 34), CO% 0.13 (max 0.32), NO 586 (max 494), CO2% 14.01, O2% 1.02.
Old numbers:
15 mph (1794 RPM)
CO2%: 14.2
O2%: 1.07
HC max: 83
HC ave: 21
HC measured: 28
CO max: 0.48
CO ave: 0.06
CO measured: .12
NO (PPM) max: 689
NO ave: 150
NO measured: 410
25 mph (1740 RPM)
CO%: 14.1
O2%: 1.10
HC max: 48
HC ave: 13
HC measured: 33
CO max: 0.46
CO ave: 0.05
CO measured: 0.12
NO (PPM) max: 706
NO ave: 136
NO measured: 353
Thanks in advance for any help.
CAT OverTemp
Target AFR
Fuel
Injector size
Chassis
Hysteresis
new = 7, old = 5
Old numbers:
15 mph (1794 RPM)
CO2%: 14.2
O2%: 1.07
HC max: 83
HC ave: 21
HC measured: 28
CO max: 0.48
CO ave: 0.06
CO measured: .12
NO (PPM) max: 689
NO ave: 150
NO measured: 410
25 mph (1740 RPM)
CO%: 14.1
O2%: 1.10
HC max: 48
HC ave: 13
HC measured: 33
CO max: 0.46
CO ave: 0.05
CO measured: 0.12
NO (PPM) max: 706
NO ave: 136
NO measured: 353
all vehicles have to go through the sniffer out there, even the new models? Jeez in Chicago only obd2 has to undergo a quick data conversation, obd1 doesn't even get called in anymore...
