The Camaro has been shifting a little rough recently (94 3.4L). It seems as if the clutch isn't disengaging completely.
When the car is off, the transmission shifts through all the gears very smoothly, if I start the engine and hold the clutch pedal to the floor, it is pretty difficult to get into gear (easier if I am moving), and every once in a while I'll get some grinding going into second.
I replaced the clutch about 60k miles ago and haven't had any problems with it, or been treating it badly (the stock clutch lasted 130k miles).
I think maybe the piston in the master clutch cylinder is shot and that's causing a lack of pressure to move the secondary cylinder, but I was hoping someone could answer a pretty simple question for me to confirm this.
TLDR:
How much movement is there in the clutch secondary cylinder / actuator on a 3.4L 94 Camaro. From top of the pedal to the floor, I get about 3/4" of any movement, it seems like it should be more.
Thanks in advance guys, want to get this taken care of before I bend a fork in the tranny or destroy my clutch completely.
TLDR:
