I hope someone can help me.I have had starting issues with my car for a few months now.It has a new FPR and the pump is only a year old.Replaced for the same problem I am having again.Here are my symptoms.Car is hard to start cold or hot, seems like it tries to stall driving down the road if rpms get below 1500 and Idle gets stuck at times.Like it will hang up at a 1000 rpms when I stop at a light or stop sign.I can hit the gas pedal and it comes right back down.Also my car has started up at around 2000 to 2500 rpms alot.Also smell fuel sometimes like its flooding.Okay here goes.My fuel pressure tests I have done.
1st test..Key turn to run,pump primes,pressure gauge goes to 20 psi and then drops 10psi and slowly bleeds down.
Test 2...Key turn to run,pump primes and makes a can crushing sound that came from the drivers side somewhere near front fender as noise is going on the fuel pressure needle is jumping with the noise.Goes to 40 psi,drops 10 psi and slowly bleeds down in about 15 mins to 0 psi.
Test 3...same as test 2
Test 4...Trying to start the car.Turn key to run,prime pump,makes same crushing noise,needle on gauge jumps with noise,hits 40 psi,I try to start and it turns over a few seconds before starting.Engine starts pressure drops to 30psi and holds.Turn car off,pressure drops 5 psi and then slowly bleeds back to 0 psi.
Test 5...Starting car with vacuum line off FPR.Prime pump,hits 40 psi,engine starts and holds at 40 psi.Put vacuum line back on and it drops back to 30 psi.Turn off car and bleed down begins.I hope someone has answers.
