Hey guys, the temps are finally down in the midwest, so of course cold temp drive-ability problems show up.
I had this wacky idle surging before, in WARM weather, it stopped on its own fairly quickly with my new maf tune. The car never stalled out completely before, I think this is a combination of a bad IAC valve (maybe a hanging worm gear) and my aftermarket throttle body that does not have a bypass hole.
I did not warm the car up like I usually do before I left, basically the car would stall out completely coming to a stop, if it didnt, it would idle at about 450 rpm, then kick back up to near normal after about 20 seconds. After the motor heatsoaked, and I mean specifically after all of the underhood components were warm the problem went away. (figures after I miss my business meeting
I have cross check my tune for map threshold issues, DFCO threshold issues, found nothing, and the car ran beautifully the day before in nearly the same conditions. O2 sensors seem to be working fine, MAF is good, EGR is deleted properly, no apparent intake leaks, will check fuel pressure in a minute.
Any idea's before I hang myself with a timing chain?
Thanks guys
)I have cross check my tune for map threshold issues, DFCO threshold issues, found nothing, and the car ran beautifully the day before in nearly the same conditions. O2 sensors seem to be working fine, MAF is good, EGR is deleted properly, no apparent intake leaks, will check fuel pressure in a minute.
Thanks guys
