Hey guys,
Got one more tricky one to bring up,
Some of you might remember a thread I started a while ago about a suspect driveline vibration,
http://www.f-body.com/forum/showthread.php?t=22972
Since then I have added 6 point sfc's, a built t56, and a chromemoly driveshaft. Keeping this really simple, it sounds like this loading vibration only happens at wot, any rpms now. Is it possible that the vibe could be tracking from the rear end? It almost feels like the case and axel tubes are flexing from the force, and sending the pinion out of alignment. My gear is starting to whine(or whir) at me under load only, deceleration makes no noise at all, since this ten bolt can't handle abuse, I never launch or otherwise do anything stupid with it, if I can help it.
I will check again any other system that could be related again; my driveline is in phase, my mounts are not torn, my balancer is correctly installed(no missing weights from what I can tell, my flywheel has been properly machined, my pressure plate balance checked, I'm unsure of where else to turn. There are NO bad vibrations or sounds if I rev up the moto at a stop, stethoscope did not turn up any positive results either.
any ideas?
Thank you guys
any ideas?Thank you guys
