I have a 67 Camero and I need to replace the mufflers. I am considering flow masters but I am open to suggestions. Some one has also suggested Pypes for Summit. Are these any good. I will be running them through a 2.5 pipe.
Muffler recommendations
i love the sound of pypes kit, i have a gibson(not sure if they make a muffler for cars) on my truck and its the perfect sound, its not loud till you get on it and there is nearly no inside drone, another company to look at is dynomax, had one on my 88 ta and was the same as my truck2009 Honda Civic EX- the daily beater
depends also on how loud you want it to be...I have run flowmaster and they have just a chamber with not much to quiet them...I am happy with my magnaflow mufflers on my 8.1 avalanche.
you should be able to find sound clips online of many mufflers
AlExtreme Memorabilia custom embroidery
Flowmasters have a reputation of not flowing that well, go figure. Not sure what you are looking for performance and cost-wise. If you can afford stainless steel, it is nice to do it once and be done with in. Magnaflow comes to mind as being one of the less expensive stainless mufflers. Borla makes a quality product, but you will pay for it, and the name.
Are you trying to match stock, keep it original looking? You can find Borla mufflers with almost in/out configuration and sizing- Some of the older 1st- gen came with chambered systems, too. Some nice ones out there if you google "chambered exhaust".2001 Z28 A4 - 160 deg t-stat, 3.42 gears, WS6 sway bars, rear springs and shocks, UMI SFC's, Torque Arm and STB, leather Firebird seats, Borla, SLP Y-pipe and lid, ZO6 cam and springs - 332 RWHP and 346 RWTQ, not bad for 'almost stock' - work in progress
"Black, the fastest color"
I had them put in an H-pipe to balance the pressures when they built my dual exh on my avalanche 2500 as I was told by many that the 8.1 can have a resonance at certain rpms and I travel alot towing...Im not sure the gains of an X-pipe compares to H-pipe.
A set of summit racing pipes, crossover pipe (H pipe) and a set of walker turbo mufflers will give great flow and reasonable, throaty sound. IMHO, stay away from flowmasters. They don't flow all that well and the sound can be a bit harsh.
a basic 2.25" header back system:
http://www.summitracing.com/parts/SUM-680100/
a basic 2.5" header back system;
http://www.summitracing.com/parts/SUM-680101/
nice stainless dual setup:
http://www.summitracing.com/parts/MPE-15896/
http://www.summitracing.com/parts/PYE-SGF60S/
closest to stock type setup:
http://www.summitracing.com/parts/PYE-SGF70/
