my speedometer went out...the other day...and i looked for a cable under the car on the tranny but there is its just the shiftlinkege and the fluid hose....thats it...i dont even see the transducer asm....in the engine bay where the haynes manual says it is....i called a mechanic and he said its run by the comp....i think he was like it could be the speed sensor or the gauge cluster......and he said it would 105 dollars just to check to see it was and he said you could tell by the odometer or something if its not runnin also....
and obviously if the speedmetor isnt workin then the odom isnt either....which it isnt....so any ideas on what i should do or where i should begin, is my cluster going bye bye cause everything else works.....like gauge wise..... i checked the fuse and replaced it...that didnt help so ????
