Fuel pump does not run with key on. No fuel pressure in the rail.
Fuel pump does not run when starting the car.
Start car with starting fluid, release key, engine will run but not idle until thoroughly warmed up.
Car is hard to accelerate and tends to backfire if throttle opened too quickly.
Quite a list of symptoms!
Ideas or suggestions?
Thanks,
Tom
Thanks,
Tom
