i was installin the heater blower motor....and when i put it in i just wanted to see if it worked so i only bolted on a couple of the nuts....and it came on....but was arching on the car....cause it was touchin the metal so i pulled the positive off...so i new it was workin i bolted the rest of the bolts back on and now it doesnt work.....could it be a bad ground?
cause there is power runnin to the wires i checked with a test light and when i plug the positive into the motor and check the negative...the light lights up also...so is it the ground thats not workin properly or could i have blown out the motor with it sparking like that....cause i dont see how it works then doesnt.....i checked the fuse and the fuse is fine....so i dont know what to do im stressed...
