The following specials will be ending on Sunday evening (6/22) -
10% off all SLP products that we carry
Strange 12 bolt rearend - $2099.99 -
Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73 or 4.10
If you have a 1998-'02 you will either need to send in your brake backing plates or we can supply a set for $170. Your axles will need to be sent in if you have ABS.
Have a good day,
Tom
Have a good day,
Tom
