I just bought the ram air hood for my t/a which is a 94, and i was going to buy the ram air box but one guy i talked to said he had to change his MAP sensor...has anyone else installed the ram air box without having to change anything.
Ram Air Box
StangstopperTags: None
No problem,I have the Ultra-Z hood and WS-6 air box[like WOLFMAN] and am using the stock MAF and all other stock GM parts.
Just make sure you have the corrugated elbow or pick up a Fernco at ACE Hardware.94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
The MAP sensor is on the intake manifold, and has nothing to do with the Ram Air inlet box. When you install the SLP Ram Air box, they supply an extension harness for the MAF sensor, which of course is moved closer to the throttle body. The only other sensor involved is the IAT sensor, which gets relocated from the inlet air elbow to the box. Wire length is fine. And if you are still running the AIR pump, the air supply hose that used to connect to the air duct needs a new hose to connect to the Ram Air box.
meyerman
I have a 2001 ws6 ram air and the top of my box is plastic - why do the pictures all show the filter exposed? Is there a mod I can do to my stock box or do I need to buy a new set up. I already removed the baffle in the in the hood for increased airflow.
C
Because these are all LT1s that breathe through the top,not the bottom!!94 Z28/UltraZ Hood & Box/1 1/2 Drop/52mmTB & Bypass/160 Stat/Pulley/ Catback & pipe/Kirkey seats/5 point belts/WW Wing/Ford9"-4.11- Detroit locker-Strange axles/ZEKE'S Heads & LT4 HC/Stainless Headers & Y/1LE Panhard/BMR SFCs-STB-Relo Brackets-Tunnel Brace-Adj Tq arm- Sway bar- LCAs-PHB/ABARE RACING 4L60E/COAN 3200/Monster tach & light/DS Loop
the 97 and before ram air set ups are more efficient than the 98+ ws6. your air comes in from under the air box. ours comes in from the top and the "connection" between the hood and airbox is sealed with a gasket. we cut the tops out of the box for better flow. the top with slots was there to cut the "sucking" noise made while the car was sitting still. a gm requirement.Originally posted by meyerman
C
the 98+ firehawks and ws6's ram air is still more efficient than the SS "ram air"...which must travel along "channels" before reaching the air box. if you have removed the baffle..there is nothing really else you can do except put a k&n filter in there if you have'nt. you can also eliminate the "accordian" bellows and use the fernco...or the slp smooth ones.
meyerman
Thanks for the explanation - I do have a K&N and I have heard about cutting off the directional fins inside the lid to make it smoother - any proof that is a really good mod.
This is my first FBody - I was a 3rd gen Monte Carlo SS owner with over 50K invested - doing 11.28 in the quarter when it was stolen in front of my gym while I was working out. It was like I lost my best friend. I had emotionally invested way to much in it. Now that I am on this board, I can see that I am not alone.
My triple black Ram Air has grown on me - my first upgrade was Eagle F1s 285 40s - super cool tread. Second I did a ProDyno Exhaust and Mecham tips (nice big ovals) freeing up another 20 hp and of course the above mentioned air flow mod. Jury is out on descreeening my MAF and a lower thermo - not truly convinced that will benefit. I have read the pros and cons from self appointed authorities on our cars - arguments otherwise??
I like the 6 speed - after owning it for a year now I can see how easy it is to fall in love again - hmmmm I wonder if it would be the same with my wife?
just kidding.
Chris
It's the first mod I did. (mostly because it was free.Originally posted by meyerman
While it's hard to nail down a documented benefit, It appeared to be worth a tenth in the quarter. Basically, you are doubling the size of the air opening by removing all the fins.
I think the LS1 guys are lucky to have the factual stuff presented in the Chris Endres book:
Chvey LS1/LS6 Performance
Lots of info on "free mods", "bolt ons" and major power adders - strokers, S/C, nitrous..... generally well support with numbers.Fred
