rear end
  • rear end
    Hey,
    Do any have any suggests on removing the yoke from the pinion shaft ? I have try wd40 with a puller I don't want to snap the yoke or a screw and also try to pry it off with a pry bar but no luck.
    Any sugggest??
    Thanks
    ACE
    I usually use a pry bar against the diff housing and pry on the edge of the yoke. If its really on there, you could probably use a slide hammer, but there really shouldnt be the need to. You do have the big nut off right???
      rear end
      Yes, I remove the nut.
        three letter: B...............F..................H
        86 Camaro (350)
        79 Blazer (FI 350)
        98 Buick Riviera (S/C)
        96 Grand Prix (Sp. Ed.)
          I would spray it liberally with PBlaster, let it sit overnight. It will penetrate into splines and free it up.
            wwell i woudl do whatever the people on here say because i ahve no clue
            1986- honda accord dx 2.0 liter carb. 4-speed automatic 200,000 miles-sold-
            1992-mitsubishi eclipse 2.0L DOHC 5 speed manual 16" ar rims -blew up- then i sold it- worse mistake ever (buying it)
            1991 hyundai excel-HA! sold
            1995 dodge neon 1.6 liter,5spd, cold air intake, short throw shift, buger bushings, stiffer motor mounts, strut towers/ anti sway, lowering kit, a couple other perf. mods , sleeper
