I just wanna thank everybody for the tips on the nittos. I will be going to the track tommorrow to try out the nittos and try the different psi and tips that you guys have told me. I will make sure to post my results. Again thanks for all your help guys.
Eric Lelina
95 Z28
Tuned by Carolina Auto Masters
302hp and 335tq
M6,GMPP CAI,1.6 Crane Gold RRs, MAC Headers,1LE intake elbow,Air Foil,!TB Bypass,Hypertech 160 Thermostat,Taylor Spiro-Pro 8mm Wires,Accel Super Coil,MSD 6al,SLP 2otl catback, Eibach Pro Kit,DMS SFCs,Hotchkis STB,BMR Adjustable PHR,Global West LCA,1LE Sway bars front and rear,KYB Gas-A-Just shocks, Energy Suspension Tranny Mount and Endlinks,Prothane Poly Torque Arm Mount,LS1 Driveshaft,17x9 SS rims.Tags: None
Must be nice, I'll probably shoveling snow as I peek at my car under the cover. Let us know how you do!96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
faster then u
Very cool good luck at the track. But I to will be sloving snow. Witch nittos did you get the 275/40/17 or the 315/35/17. Please poust and let us know how the nittos worked.
