Just bought the scanner, read code 32, spent the last two days learning about EGR, changed the EGR valve...but the problem is still there. It's the same old story-stumble at low RPM, rough, surging idle, and surging on acceleration. If anyone can give insight on these numbers, I would more that appreciate it.
So I held the brake, took it to arougn 1000rpm, engine surged and here's the capture
RPM 950
coolent 224.6
minifold air temp 131.4
MAP sensor 2.68v
Trottle sensor 0.96v
throttle angle 10%
battery 12.8v
barometric press 4.90v
left O2 646mv
right O2 66mv (both ranged 50-850mv)
left block learn 119 (while driving these changed constantly)
right block learn 124
left integrator 118
right integrator 132
left inj pulse 5.4ms
right inj pulse 6.3ms
mass air flow 19gr/sec
ccp duty cycle 0.0%
spark advance 32
knock retard 0 ( got 1 degree while driving)
EGR duty cycle 99.4%
closed loop on
RPM 950
coolent 224.6
MAP sensor 2.68v
throttle angle 10%
battery 12.8v
left O2 646mv
left integrator 118
ccp duty cycle 0.0%
spark advance 32
closed loop on
