Path of Exile 2 (PoE 2) is renowned for its challenging bosses that test players' skill, build optimization, and ability to adapt to complex mechanics. Among these formidable foes is Ashar the Sand Mother, a unique monster and the final boss of the Poe 2 trade third floor of the Trial of the Sekhem As. As a ruler of desert chaos and poison, Ashar demands careful preparation and precise execution-but with the right strategy, you can claim victory and secure the rewards she guards.
This guide breaks down everything you need to know to beat Ashar, from pre-fight preparation to countering her deadliest attacks. Whether you're a seasoned PoE veteran or new to the game's endgame challenges, these tips will help you navigate her sandy arena and emerge triumphant.
1. Before the Fight: Preparation Is Key
Ashar's battle is not one you can rush into blindly. Her attacks deal heavy chaos damage, and her arena is filled with environmental hazards that can quickly turn the tide against you. Proper preparation will significantly reduce the fight's difficulty and increase your chances of survival.
Gear and Resistances
Chaos resistance is non-negotiable when facing Ashar. Many of her abilities infict chaos damage, which bypasses regular armor and can drain your health rapidly if unmitigated. Aim to cap your chaos resistance (75%) using gear, flasks, or passive skills-this will be your most important defensive layer.
Additionally, prioritize gear with high life or energy shield to boost survivability. Movement speed is another critical stat: Ashar's attacks are mostly area-of-effect (AoE), so being able to dodge quickly is essential. Look for items that grant increased movement speed or use movement skills like Flame Dash or Leap Slam to stay agile.
Relics and Buffs
Equip relics that provide chaos resistance or honor restoration-honor is a vital resource in the Trial of the Sekhem As, and losing all of it will end your trial early. Sanctum buffs like "less damage from mobs" or "less HP on mobs" can also give you a significant edge, so seek these out before entering the fight.
Build Considerations
While any build can defeat Ashar with proper preparation, some are better suited than others. Melee builds should focus on high single-target damage and mobility to avoid her AoE attacks, while ranged or spell builds can stay at a safe distance but must remain vigilant of her projectile and burrow mechanics.
Curses like Temporal Chains or Enfeeble can slow Ashar's attacks and reduce her damage output, making her easier to dodge. Defensive auras such as Purity of Fire (to counter any secondary fire damage) or Grace (for evasion) are also valuable additions to your build.
2. Locating Ashar: Unlocking the Fight
Before you can face Ashar, you must first unlock the Trial of the Sekhem As. This requires defeating Bal Bala the Traitor in the main story to obtain a Djinn Barya, which you'll use to activate the trial's relic altar.
Ashar resides at the end of the trial's third cycle, after defeating Earthbreaker and the Terracotta Sentinels. To access her arena, you'll need a level 65+ 3-trial Djinn Barya or a level 77+ 4-trial Djinn Barya-the higher the Djinn Barya's level, the more powerful Ashar will be, so choose wisely based on buy POE 2 Exalted Orbs your build's strength.
Before entering the arena, interact with the nearest checkpoint to ensure you respawn close by if you die. This will save you time and frustration as you learn her mechanics.
Relics and Buffs
