Originally posted by mmcgehee9989 The guy I purchased my 93 Trans Am from said that the car had a posi trac rearend and that they come stock. Is this true?
Yes and no.
No it does not have "posi traction" That term is used by a different manufacturer, not Chevrolet.
Yes, your car does have an equivelant. It is called "limited slip"
The rear diff. in your car has a clutch pack in it between the left and right wheels, allowing them to move independantly from eachother under low load situations around corners.
When you change the fluid in the diff, be sure to add the proper amount of GM limited slip addative.
No it does not have "posi traction" That term is used by a different manufacturer, not Chevrolet.....
To my knowledge, and looking at the window stickers for several of my past Chevrolets -going back to 1963 - "Positraction" is the Chevy trademark for a limited slip differential. On my Pontiacs, it was trademarked as "Safe-T-Track".
I don't think the "positraction" name has been used by the factory for quite a while, but it always was a Chevy trademark.
That what happens to my brain when I'm doped up on cold medicine. You are, of course correct. Thanks for straitening me out.
