What's the most tire width you can fit on a '94 T/A? Right now I have P285 40 ZR 17's and was thinking of putting P295's is that possible? Would there be any tire rubbing? Right now I have no problems at all.
Rear Tire width
I did a search on the tire rack and nobody makes a 295 wide 17" tire. The next tire size up is 315/35-17 and that calls for a 10.5-12.5" wide wheel.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
You can fit the 315 on an 11" wide wheel, but you need the right backspacing and even then, if your rear isn't centered exactly you may need to "massage" the inner wheel well for some clearance. You need to use the Corvette GS backspacing, not the ZR1 backspacing.69 Z28 with JL8 factory 4 wheel disc brakes, crossram, transistor ignition, radio delete, heater delete - being restored
2000 SS Camaro daily beater
You're probably better off sticking with that combination. I had a set of the 315's on ZR1 17x11 wheels on my old 93 Z28 and they were the wrong offset and stuck out of the wheel opening about 3/8 to 1/2".69 Z28 with JL8 factory 4 wheel disc brakes, crossram, transistor ignition, radio delete, heater delete - being restored
I have 315's on the back of mine, and I will not go back to a 275 unless I absolutely have to. I have American Racing rims, and they did a lot of research when they did their offsets on the 17X11 for f-bodies, because it is dead on. No massaging, no adjustable PHR required, just bolt them up. They fit in the fenderwell too, and look VERY evil from the back
This is a stupid question I think, but since I was raised up in and drove a front wheel drive car... I think I need to ask it seeing as my Celica and my Sentra had all the same size tires and the same makes of tires on them, on all fours...
What is the point of having bigger wheels on the rear than on the front?...
And why don't you keep them the same on the front and the rear (Size wise... you know 235/55)?...Thanks
MaraSport
tabahr
The more meat on the road, the better the traction. The rear wheels do not need clearance for turning, so it is easy to fit wider ones back there for added traction.Originally posted by MaraSport
just dont put the 315's on anything less than a 10.5" rim folks......
11 prefered. if you do......you dont gain any size in footprint.... all it is ......is cosmetic. and the tire casing is not happy....the bead is stress..and you stand a chance of poping it off the bead if the wrong chit happens..... heat build up prematurely wears the tire ddue to unatrual flex in the casing and tread blocks.
fyi.
