Hay I have a 1995 Formula with the LT1. How much horsepower does this car have? I also have installed a functional aftermarket Ram Air hood on and a K&N air filter. Just curious what she is putting out. Thanks.
hosepower
I agree. 290 is max, I would say. This is assuming you do not have a dual-cat car from 95. If you do, then maybe 295. However, this is "factory rating" + your ram-air system, which vary from car to car.
In fact, the dual cat system isn't even proven to gain 10 hp over single cat system (at least from what I've seen on the dynos). If you really want to know, pay ~$65 and get it dynoed for the RWHP.94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
HOSE POWER!!!!!96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
Originally posted by N20LT4Bird
HOSE POWER!!!!!
bluefirebird94
stock numbers
i hade mine dynoed the other day it is a stock 1994 firebird formula it hade 230/239 i was pleased for stock
