Power Plant can chew up a raid fast if you rush it blind, so most players start by learning where the good loot tends to appear and what spots are worth the detour. If you're trying to build up Delta Force Items without wasting half the match, the trick is to move with purpose, check the nearby spawn points first, and keep one eye on your radiation meter the whole time. The map rewards people who stay calm and make small, smart decisions instead of sprinting from room to room.
Start Close, Then Work Out
The opening area is usually where you get the easiest wins. You can often find supplies in the first warehouses, office corners, and utility rooms near spawn, and those early checks matter more than people think. A lot of players skip them because they want the big loot, but that usually ends with them walking into contamination too soon. I've found it's better to clear the safe side first, grab anything useful, and only then decide whether the deeper plant is worth the risk. That way, even a rough raid still gives you something back.
Reading the Plant Without Overthinking It
Once you push inward, the map starts to feel less like a factory and more like a maze that's trying to waste your time. Radiation builds quickly in certain corridors, and if you do not already know where the decon stations sit, you can get forced into a bad route very fast. This is also where a lot of players make the mistake of fighting every bot they see. You do not need to. Just clear the enemies that block your path and keep moving. Even your loot choices matter here; grabbing a cheap Delta Force Tekniq Alloy on the way out can be the difference between a decent run and a really profitable one, especially if you've already spent time dodging radiation and clearing cramped rooms. The main thing is not to get greedy in the reactor side. That area can pay off, sure, but it also punishes slow movement and bad map reading.
Where the Better Spawns Hide
Some of the stronger 3x3 spawn locations sit in places people walk past all the time. Look around blue containers, beside desks in maintenance offices, under shelving in lab spaces, and near industrial gear that seems too ordinary to matter. That's usually where the useful stuff sits. A few locations are tucked on higher walkways or upper platforms too, and those are easy to miss if you only move at ground level. You do not need fancy routes for every one of them. Sometimes a small climb, a side ladder, or a narrow shortcut saves more time than any full sweep of the building. That is why map familiarity pays off here more than raw aim.
Keep the Route Simple
After a handful of raids, most players settle into a loop that feels natural. Check the first rooms, watch the radiation, cross to the safer interior paths, and only dip into the hot zones when the timing feels right. That rhythm works because it cuts down on panic. You stop guessing, and you start recognising which rooms are worth opening and which ones usually come up empty. If you're farming the map often, it helps to remember that not every spawn is active every raid. Repetition is what turns the plant from a messy grind into a route you can actually trust, and once that happens, extraction gets a lot less stressful.
