I plan on painting my calipers this week. My friend just did his on his SS. He didn't mask anything of on the caliper he just kind of shot them. I plan on masking the pucks off. I bought Caliper spray paint from Pep Boys. Is there anything I need to be really careful of when I paint them?
Caliper Painting
Caliper Painting
-Rico
94 Camaro, 3.4L, M5, Quasar Blue, SOLDTags: None
Some 'prep sol' or wax and silicone remover or a paint prep cleaner that you use just before painting should clean the calipers nicely. Let the stuff evaporate before painting though.LT4KM, 160' TS, MAF ends, TB-bs, 1.6 R/R, SLP CAI, LCA, tierod, 17x9"F/R, 275/40R17 tires. WS6 Muffler, LS1 DS. 21mm rear sway bar. Soon to be LT4 heads, intake, & HOT cam
I Dremeled mine with a wire brush. Note that it is hard to keep them clean. Mine are red and turned dirty pretty quickly.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
Thanks for the pointers everyone...I will be painting them this weekend. My WS6 is black and I am going with a Red Paint. I let you know how it turns out...I might change my brake pads while I'm there too...thats a good point with the "keeping them clean "thing. Thanks!-Rico
Careful of wheel cleaners too. I painted my calipers with some good stuff from Eastwood Co. But after using Eagle 1 wheel cleaner, some of the paint started to flake off. It's not too bad so I haven't repainted them. But I stopped spraying the cleaner on the calipers and just use a nylon brush and soapy water.
I used some 1200 degree red grill paint for mine about a year ago and have no problems, but my car dosen't see much road either. I just wiped down the surfaces to be painted with some carb cleaner and a rag and masked off what I didn't want to paint. I used about a TON of news paper to fill/cover the entire fender and inner well cause I hate overspray. Just take your time and get about 8-10 thin coats applied and you should be ok.
I did my intake the same way later...lots of tape and paper, but I was able to do it on the car without removing much.
Flash - '97 Black WS/6, Intercooled Powerdyne 11#
**-** BOOST, it's no replacement for displacement, and there's definitely no replacement for having both!
came out great...now just gotta get the decals.
-Rico
Looks nice! One word of advice...do some heavy braking to heat them up at least three or four times before using any cleaners or blasting them at the car wash. Especially if that is a ceramic paint, this should help "bake on" a good hard finish.
I red on other forums that they placed the decals on after painting and then used a temp. resistant clear coat to protect it all.
Haven't done it myself but am thinking about it come spring.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
Search for Ceramic High Temperature Caliper paint. I used it and this stuff is pretty good. I only did the front calipers, I prefer the bare aluminum look to the rear PBRs. The best way to do this is to sand the exterior surfaces smooth, thoroughly clean them, remove the pads and hang them on coat hangers for the final painting. Plan on your car not moving for a couple of days.
Paint in 5-6 light coats,
until each coat is dry before the next coat is applied. Do the final coat a little heavier and again wait to dry completely. You can follow it up with clear if you want the ultimate protection. I did mine a few YEARS ago and they still look great. In the pic below, was the original silver I did after the stock Cad plating wore off. I actually think the couple of coats of silver made the red turn out a little better. Must be the multiple coats.
Has anyone tried powder coating? Harbor Freight has a powder coater for $56.00. You could remove the calipers, disassemble them, clean and smooth, then powder coat and bake in the oven. Any thoughts?Kevin Thornton
91 Z28 Black, 6" cowl hood, 468 ci,
850? Holley, MSD 6AL, TH 350,
3.73
1989 Trans-Am, Ram-Air hood, 5.7
TPI, 700r4, 3.27 9 bolt, K&N, No
screens on MAF, Cat delete,
Flowmaster cat-back, 245x60 15
frt, 295x50 15 r
15.109@91 1/4
sounds like a lot of work....-Rico
