my head lights on my 94 firebird formula make a humming noise even after the lights are up and when i put them down my roomate told me the motor is bad but i would like a second opinion cause a new motor is a little pricey if it is bad does any one have an extra one lying around they want to sell for a good price
anyone know about firebird head lights
bluefirebird94Tags: None
that does sound like the motor is going bad , what usally happens is that the gear inside wears out, myn went out not to long ago and i went and bought a new one for $250.00,
but you can by just the gear for about $70 bucks. the gear is made of some sort of metal ( cant remember) but with that one it wont happen again. someone will eventually give you the site where yuo can get it .Miss My Bird
Yup sounds like the gear. This happened on my old 95 Formula. Follow the link from Joe1320, get the brass gears and fix both of them. If one is going out the other one will strip out soon too. It will be bulletproof once you're done just make sure and clean it and use plenty of epoxy. Worked like a charm on my Formula....too bad it was wrecked a week after the install. Blazer got a good deal on my gears out of it though
.......Later
bluefirebird94
thanx
thanx for all the info it says on the sight i might just be able to turn the gear and use the other half. alos there is a brass one i can buy i really appreciate all of the info. does any one know where to get a use dash board cover that is not cracked
Re: thanx
I would go ahead and get the brass gears. I did the free fix and it only worked for a month or so and then it stripped that side too. Unless you're really broke and want a temp fix do the brass gears. You'll only have to do them once. By the time I broke down and bought the brass gears I had taken the motors in and out about 6 times or so. Now I can replace both motors in like 15 minutes LOL. Good luck......LaterOriginally posted by bluefirebird94
