Sorting storage for a six week gap between apartments
  • Sorting storage for a six week gap between apartments
    Week One: Realising the timeline
    The realization that my old lease and my new lease were completely out of sync hit me about a month before moving day. The landlord wanted me out on the exact day the contract ended. The new place was not going to be ready for another six weeks. That left me with a full one bedroom apartment of furniture, clothes and kitchen appliances with nowhere to go. I had to figure out what to do with it all while I stayed in a hotel.
    I am the kind of person who looks at two options, weighs them up endlessly, and then picks the most boring, standard route available. My first step was trying to understand how the industry even works here. I found a guide on Coming Soon UAE about short term storage Dubai that actually explained the mechanics of it all. It is a solid read if you are stuck in this exact situation. The piece separates renting an actual unit from per item storage. It also includes a comparison table of operators that looks at their minimum term, their starting price, whether they offer pickup, and their area.
    Reading that guide helped me decide, though I will admit it made me much more cautious than I really needed to be for a simple short gap. I started worrying about long term risks that simply do not apply when your sofa is only going to be sitting in a room for a month and a half.
    Week Two: Unit versus per box
    The main decision you have to make early on is the format. Per item storage means a company takes your individual boxes or furniture pieces away and you are billed for what sits on their shelf. Renting a unit means you are given a set room size and you can pack it full to the ceiling.
    If you are comparing the two models honestly for a one bedroom flat, the unit usually wins. The per box model is brilliant if you have five suitcases of winter clothes or a few boxes of books. Once you add a mattress, a dining table, a television and twenty boxes of kitchenware, the per item billing gets very complicated. You are paying for the awkward shapes of your furniture taking up their shelf space.
    I chose the boring option. I rented a standard unit. It meant I knew exactly what the room would cost, regardless of how badly I packed my boxes or how awkwardly my armchair fit inside.
    This whole gap situation is incredibly common. If you spend time reading the UAE government's housing pages to understand your rights regarding tenancy contracts, you quickly realize that moving dates rarely line up perfectly. Landlords want their properties occupied immediately, and vacating tenants often leave delays in their wake. Having a gap plan is just part of renting here.
    Week Four: Finding the right facility
    Once I decided on a unit, I had to pick an actual operator. There are dozens of them scattered across the industrial areas. Some are massive warehouses, some are tiny rooms in older buildings.
    I used a directory called Top 3 Storage Dubai to narrow things down. It takes a slightly different approach and splits the question into categories. It groups the facilities by self storage, cheapest, climate control, business, and operators that collect. This was helpful because it stopped me from calling places that only deal with commercial inventory. I just needed a simple self storage room with climate control.
    Comparing the operators in pairs is the best way to keep your sanity. I would look at one of the bigger chains and compare it to a smaller independent place. The bigger chains usually have better lighting, wider corridors and smoother trolleys. The smaller places often have slightly more flexible access hours or less strict rules about the exact day you move out.
    I ultimately went with a well known operator in a major industrial area. They had a minimum term of one month, which fit my six week timeline perfectly. I would just pay for the second month and leave halfway through.
    Week Six: The physical move
    When the actual week of the move arrived, the theory turned into heavy lifting. If you are doing this yourself, or even if you hire a crew to help, there are practical things that go wrong.
    The first issue is always the box count. You will have more boxes than you think. A one bedroom apartment looks small until you start putting every single fork, towel and book into a cardboard square. When you rent a unit, you have to stack these boxes high. The heavy ones must go on the bottom. If you pack fragile items in a weak box and put it at the bottom of a stack, the weight of the boxes above it will crush it within a week.
    Another detail people forget is the temperature transition. If your items are moving from an air conditioned apartment into a non climate controlled moving truck in the middle of the day, condensation can form inside sealed plastic bins. By the time they reach the climate controlled storage room, that trapped moisture has nowhere to go. I used cardboard boxes instead of plastic tubs for exactly this reason. Cardboard breathes, which stops your clothes from smelling damp after six weeks.
    The next issue is access. You might think you will not need anything from your unit during the six weeks. You are wrong. You will inevitably pack a document, a specific pair of shoes, or a charger that you suddenly need.
    If you pack your unit by just shoving everything inside and closing the door, you will never find that item. You have to leave a small walkway down the middle of the unit. Put the things you might actually need near the front. Put the sofa and the mattress right at the back.
    Week Eight: Moving out again
    Taking your items out of the facility and into the new apartment is much faster than putting them in. However, you need to be aware of the checkout process.
    Most operators require you to give notice before you empty your unit. You cannot just show up, take your things, and leave the key on a desk. You have to sign paperwork to close the account. If you forget to do this, they will keep billing you for the next month because, as far as their system is concerned, you still occupy the room.
    You also need to sweep the unit clean. If you leave empty boxes, packing tape or broken furniture behind, they will charge a disposal fee against your deposit.
    Here are the practical things you need to check before you sign anything:
    * Ask exactly what happens if you stay three days into your second month, because some will pro rate the extra days but many will charge you for the entire full month.
    * Check the physical distance from the loading bay to your specific door, as a unit might be cheap just because it is down a long corridor and around three tight corners.
    * Look at the ceiling to see if there are exposed pipes directly over your unit, and ask what runs through them if you spot any.
    * Confirm the access hours on weekends because a place might say it is open every day, but Sunday hours are often heavily restricted.
    * Bring your own padlock instead of buying the standard models sold at the reception desk, so you are the only person with the keys.
    The gap between apartments is frustrating, but treating the storage phase as a completely separate, standalone move makes it manageable. You pack for the unit, not for the new apartment.
