i have just checked my 93 formula after some heavy rain and the rear floor behind the front seats is very wet to the point of a puddle any clues where it may be coming from and how to cure it many thanks russ
Hey I have the same problem with 1993 TA, whenever it rains it gets wet behind the seat to a point of a puddle. While getting an oil changed checked it out underneath, in that same location are weld points on the floor boards, they were rusted so I had the guy clean it off, and he used some kind of epoxy on that spot, but no luck. I looked closesly, the previous owner used little caulking in area of the door step, under the door seals, in the corner behind the driver side seat. But still remains a mistery. I have no ttops.
1993 TASOLD
having just had another look at my 93 forumla (no t tops) when the doors are shut there is a gap between the glass and the seal at the top of the door but the glass is touching the seal at the top. with the door open ther is a lot of movement of the glass. any help would be gratefully receved
you may need a new weather stip install. ive seen this before on even later models.
There are adjustments for the glass if you take off the door panel. I recently did this for my Z and quieted down the noise level and fixed a very small gap. Also had the same problem on my Formula. Water would get in if it rained really hard and was windy. If it's too much to adjust out you might need new weather strip like Ken said, in that case check J.C. Whitney, they usually have that stuff.......Good luck
My 94 Formula would leak water while I was driving. I fixed it by installing T-tops and new weather striping.
Gary94Formula
2002 V6 Firebird (wifes)
2013 GMC Sierra (mine)
2011 Cadillac CTS4 (wifes)
