ok guys here is what i want to do i wanna bypass the collant that flows through the throtttle body. how do i go about doing this and will i still be able to use my heat.
bypassing the coolant to the throttle body
I think this is what you need to do.
http://www.geocities.com/MotorCity/6647/ta93/tbody.htm
Use as Injuneer recommeded in a previous thread of yours a 3/8" barbed hose connecter like this to make the connection
http://www.simgo.com/stainles.htm
From what I remember reading is, the TB is heated to warm up the air in extreme cold weather condition i.e. Winter. The heat should still work even with the TB bypassed.
Guys please correct me if my statement is wrong.
Rene
No effect on heater at all. It just bypasses the throttle body. On my 95 Formula I didn't even need a connector or extra hose the stock one reached fine. I think it's on the older models 93-94 that you needed the extra hose. I'll know when I get around to doing my 96 Z28......Later
check out the Dyno Charts http://www.ws6.com/mod-8.htm
raul.garcia
TB Bypass
This is the original 48mm TB from my 88' 350 TPI. I had it bored it out to 52mm on a vertical lathe with the air-foil installed. The throttle plates are from 6 cylinder TBs, and a perfect fit, no filing to fit needed.
The area covering the TB coolant passages & hose barbs were removed leaving only the IAC motor housing. a cover plate was fabricated from aluminum to cover the TB coolant passages.
Modified bored out 48mm TB.
Bottom of TB
Sort of..... what is happening here is the lack of heat in the TB is not causing the typical loss of power once the motor heats up. Ever notice the car runs stronger before it reaches full temp? A combination of a 160º thermostat, reprogrammed fan control and the TB coolant line bypass keep the engine running up to it's potential rather than loosing some HP due to heat soak. So really, you aren't gaining HP, you are stopping the HP loss due to heat.Originally posted by redbird94
and this is 6 hp?
