I know this is probably a really stupid question, however, I figured since there are quite a few detail guru's on this board, I could probably get a right answer. Anyways, heres the question. Will the snow brushes that you can purchase at like Autozone cause scratches in the paint if you accidently swipe it when trying to clean the snow off the windows? I've always wondered this, but then I thought that the manufacturer couldn't sell them if they scratched the paint... Does anyone know for sure??
Thanks,
Jeff
Thanks,
Jeff
but spent some serious time later getting the marks and scuffs out. I'd say the scratches you get from a soft brush like that (wet from snow anyway) are not any worse than the sand and salt abrasions you will get just driving in the elements. Don't worry about it unless you are seriously into trophies and such....even then you can "fix" it back with a simple regiment of Zaino
, LTCC Coil Per Cylinder Ignition, OPTI High Voltage Deleted, 160, Short Stick, BMR-STB, adjustable Shocks, PP+ w/scan, !CAGS, Flowmaster 3" cat-back... 43k miles as of Aug. 2006
..... then..crawl under the cover..startem up..letem get alittle warm under the cover..and just pull the whole mess off.......
