what do you run in the 1/4, what are your mods, and what was the best all around mod
what do you run
my previous Z-28 a-4 with 2.73's ran a 14.298 with a flowmaster cat back, i then removed the cat, put in 3.73's and got it to run a 14.0. during that run the serp belt broke and cut the #7 plug wire at about half track. i un hooked the fuel injector, and drove it home. i fixed it at home and drove it 6 days. the day i was going to head back to the track that next week i was t-boned at 40+mph and the car was totaled. ill let you know how the current car does with the same mods + ram air and a ton of suspension work.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
geez - I thought I had some bad luck.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
11.6 @ 123mph (1.6 60' - getting there)
Mild 383 stroker..... best N/A pass is 11.5@117. With a 125-shot of juice, it ran 11.1@127.6mph (ET should have been at least 4/10ths lower... the nitrous didn't hit until about 100-ft off the line). It running a 300-shot now, but I don't have any track times.Fred
a tight forum......
(thats what i run)
Car needs some TLC right now...
I never ran the car completely BONE stock, the first time I ran it, I had a K&N air filter in it, and that was my only "mod". On my first ever pass down a drag strip, I rattled off a 13.5 @ 108. Later that day I improved to 13.3 @ 109. So "almost" bone stock my best time was 13.3 @ 109.
The mods I now have are: MTI lid, MAF ends (which some suspect are costing me power, and I may go back to the stock ones), SLP bellows, B&M shifter, PPC long tube headers, off-road y-pipe, Corsa cat-back, and BFG T/A KDW 275's.
The car needs some TLC... after missing a shift and driving the revs sky high, I am suspecting some damage may have been done to the pushrods or valves (maybe even the pistons --). It drives fine around town, but despite the mods listed above, I am now trapping at 105 mph. In addition to possible problems there, I am also running pretty rich at WOT, and I am getting significant amounts of wheel hop which never used to happen... (tranny mount?? or possibly the result of the stickier tires???)
At any rate, I have already made an appointment at LS1speed in the spring time where I will hopefully be able to get all of those problems corrected, and get her running as strongly as she was when she was new. I have a factory freak, so I am told
If I can get the dyno tuning done (to correct the rich A/F ratio) after those other problems are checked out, I will be looking for rwhp #'s in the 350's or higher, and 1/4 mile times in the high 12's -- mid 12's if I am luckyFormer Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
The only car I've ever run is one of my Syclones. I'm not much into racing.my car:
'86 Caprice Classic. Soon to have a 350 crate motor. Shooting for 300rwhp.
the project:
check the www for pics, but a '36 Chevy Master Sedan, MII front end, Jaguar IRS, '93 LT1 powerplant with plans for 350rwhp, and many many other goodies
Originally posted by wako29
is that you Stealthbomber?
Originally posted by wolfman
my car:
the project:
