Hey guys, ive been installing power windows and locks from a 96 z28 into my moms 94 v6 camaro, its been REALLY fun, considering every thing is riveted in! Well, the regulators were, had to drill them out, and no place around here carry's anything bigger than a 3/16" rivet, so i had to pick up some 1/4" bolts, nuts, washers, etc, and try to get them in there. Talk about a pita! But i did manage to get teh drivers side lock in there, and 3 of the 4 bolts to the power window regulator, need to move the window to get to the 4th, so that means i need to run some wires.
Ive got teh ENTIRE harness with EVERY plug on it from door to door. Even has the little boots that go between the door and the frame. My problem is, how do i access the cars wiring. Under the drivers side, there is a plastic panel covering alot of stuff up, but i cant get it out. Other than that, do i need to remove the dashboard, to get access to all the underdash plugs and such. If so, how hard is it, whats involved. Any help is appreciated, i searched and found NOTHING.
