Contrary to some advice from others, I am going to try building my own 12 bolt rear. (Im stubborn like that). If it works, I can do it about 1000 - 1200 less than a moser. I bought bare housings - one 12 bolt, one 10 bolt f-body. I am going to do the measurements, cut and paste the bracketry, modify the length of the axles tubes, add an eaton posi, moser axles and c-clip eliminators, etc.... I'll let you guys know how it turns out.
My question is..... Does anyone know how to figure out the rpm you would be turning through the traps with a certain gear ratio? I am going through at about 6500 on nitrous and I have about 300 - 400 more rpm to "play with". I was thinking of going with a 4.10 gear in the 12 bolt. Does anyone know how to figure out if it will work without having to shift into 5th gear before the traps?
