98 6-Spd WS6 T/A, 80K miles.
Clutch engagement point is very close to the floor. Clutch makes a sqeaky noise when depressed. When the car is cold, quick shifts on the 2-3 and 3-4 make a grinding noise when going into gear......... goes into gear every time. When bone cold, it even does it at low rpm, quick shifts only.
After driving the car for a little while and the car warms up and after using the clutch some too...... the grinding noise goes away and it shifts fine. I initially thought I had a synchro problem but since the noise goes away after using the clutch for a bit, I'm almost positive it's the slave or master cylinder issue.
Thoughts anyone? Do you have to pull the tranny to change out the slave cylinder. Seems like I've read about an adjustable slave cylinder rebuild kit. If I'm trying to save money, should I mess with the adjustable kit or just replace the slave cylinder(if that's the problem)?
