On a lt1. The left side of the throttle body has two vaccum lines running to it the lager top on goes the vavle cover the lower smaller one goes to what? And if this lower one was leaking would it throw a code?
Question
Re: Question
fast idle step down if my memory serves me well.Originally posted by Bojangles1432
__________________
Wolfman (KenC)
Chief Moderator
Founder: MAFBA (retired)
C0-Founder: CompTA Owners Assoc. (retired)
Member: Firehawk Assoc. of America (retired)
1997 CompTA #139 (fFOR SALE)
1997 Firehawk #132 (FOR SALE)
2003 Envoy SLT (hers)
2004 Envoy SLT (mine)
P.O.C.: Wolfdog Rescue: Spotsylvania County, VA.
Volunteer: Full Moon Farm WolfDog Sanctuary http://www.fullmoonfarm.org
Charter member: Wofdog Rescue Resource
The left as in the drivers side or the left as in the passanger side. I just took off the cover over the throttle and I don't see any coming off of what I would call the left side. Are you talking about the passanger side which is this http://shbox.com/1/tps.jpg picture? The passanger side, http://shbox.com/1/map.jpg has a plastic tube that goes to something that you can see in the left side of this picture where you see that connector.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
tabahr
Re: Question
Canister purge solenoid.Originally posted by Bojangles1432
I dunno if it would cause a code if broken. If my car wasn't in storage I'd unplug mine and see what it did.
The lower/smaller connection is the vacuum line for the EEC canister purge solenoid, as indicated in the response above. In OBD-I cars (93-95) a vacuum leak in this line (or unplugging it) will NOT set a code. In OBD-II cars (96/97) it will set a code for "flow during non-purge". The OBD-II cars have an additional flow detector in the line from the purge solenoid to the throttle body to detect leaks and non-flow when it is supposed to be flowing.
In your 1994, you will NOT get a code/SES light, but if the system is leaking, you will have a vacuum leak.
The upper/larger connection is in fact not a vacuum line, but is ported to a location in front of the throttle body blades. This line supply MAF measured, filtered air to the passenger side valve cover, and this air is pulled through the crankcase and out the lifter valley by the PCV valve on the drivers side of the intake manifold.Fred
