Ok, I have a 97 Z28 six-speed.
Here's the problem: Wheather I accelerate from a dead stop or cruising my motor hesitates randomly between 4500- 5800rpm in every gear. The higher the gear, the more it hesitates. It feels like it is running out of fuel, but I checked it and its fine. It is throwing the P0100 code which is a MAF sensor circuit code. I was wondering if any one else had a similar problem. If any one has any ideas please post them. Thanks.
. Seriously though, I would guess that either your connector is corroding a bit or possibly a wire in the harness is broken or shorting. Pull the connector on the MAF and take a look, then plug and unplug it a few times for good measure and see if this helps.
