i have a 99 t/a auto... i have headers , intake, exhaust with a set of nitto tires... what would i be expected to run???
what should i run
silver 99 taTags: None
Depends on too many variables - the car itself, weather, track conditions etc... But if I were to give an average, I would expect low to mid 13's with your mods.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
silver 99 ta
and is there anything else i can do for traction.. i dont have tcs and i still burn the nittos from a 30 roll and it walks real bad... any suggestions
BAS
At the track, run 22-20 psi in the nittos..
Do you do a nice burnout? Heat em until you see the smoke billowing in your rear view.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
silver 99 ta
