CAI?
  • CAI?
    everyone is posting CAI what does that mean
    1994 firebird formula
    Cold Air Induction
    97 SS #C007
    Polo Green w/ tan leather A4
      Here is a bunch frequently used
      TB = Throttle Body
      STB = Strut Tower Brace
      SFC = SubFrame Connectors
      MAF= Mass Air Flow sensor
      IAT = Intake Air tempreture sensor
      TPS= Throttle position sensor
      IAC= Idle Air Controller
      O2= oxygen sensor
      MAP= Manifold Absolute Pressure sensor
      RAP= Reserved Accessory Power
      VATS= Vehicle Anti Theft System
      AIR = the airpump (smog) system
      CAI = Cold Air Intake (or induction)
      EGR= Exhaust Gas Reburn
      OPTI= the distributor on the LT1 (optispark)
      M6 = Manual 6 speed transmission
      A4 = Automatic 4 speed transmission
      1LE = an available handling / special performance package
      LT1 =the code for the V8 offered from 1993 - 1997
      LT4= a rare special high performance version of the LT1
      LS1= the code for the V8 offered from 1998-2002
      SLP = A company that upgrades cars for GM.(Streel Legal Performance) and sells goodies outright also.
      1.6RR= 1.6 ratio roller rockers
      Many times, if someone removes a part from their car, they will indicate it by listing the part name with an ! in front of it.
      ex..
      !TBcoolant = removed the TB coolant lines
      !MAFscreen = descreened the MAF
      !VATS = disabled the VATS
      !AIR = removed the AIR system
      !IAT = bypassed the IAT
      !EGR = removed the EGR valve
      If someone says they have a 1LE shaft, they are saying they have the aluminum driveshaft that came as part of the 1LE option. The same goes for 1LE swaybars and other parts.
      LT4 heads or LT4 hotcam would indicate that a person installed heads or cam for an LT4 into their LT1.
      I'm sure threre are a ton more, feel free to add to the list.
