The engine is stock..almost (ported&polished heads with thinner head gaskets). One week with DTC "misfire" located at the first cylinder (easy access..thank God)..spark plug & wire OK...So the culprit was the fuel injector...a pair of tinny hits and 2 "cleanings" help a lot...but I want to replace it.
I've heard the Bosch ones are pretty good but I would like to follow your advice..
Thanks in advance for your imput
Jose L Hidalgo
Jose L Hidalgo
IMHO, replace the whole set. We aren't dealing with an economy car/ beater, we're dealing with a performance machine. Chances are if one injector is fouling/worn, others are not far behind. I've used Lucas, Bosch and have known people that use others they all are pretty much the same, just slightly different features/benefits. Just do yourself a favor and get a flow matched set, install them and reap the rewards of knowing it's right.
