abs inop ?
  • abs inop ?
    after having just had a little snow storm here in the the uk my 93 fourmla has started to light the abs inop lamp. if i pull the abs fuse then put it back in the fault clears up for a few days then comes back any idears guys?
    mirror burn out movie top ten burn outs
    I've heard of the connectors at the hubs getting dirty, and needing to be cleaned up and reseated.
    Also, if the 3rd brakelight is burned out the light will come on, but that does not sound like your problem.
    You can have your ABS code read and see what it says.
      my car does that too and my brothers too
      its sumthin to do wiht the sensors
      1994 firebird formula
        thanks
        thanks guys
          inop
          try the connections on your third brake light . my abs inop was on and i had a blown bulb changed the bulb never had a problem again .good luck
          have you out run a ford lately
