verifying a WS6......
  • verifying a WS6......
    This is probably a newbie question, but I'm looking at getting my first 4th gen WS6 (a '97) and need to know what ways can I verify it's a true WS6 and not a clone. With so many aftermarket hoods and airboxes out there, are there ways through the VIN or option codes that I can use to verify a true WS6?
    Thanks!
    Dave M
    Dave M
    There is a computer printed "build tag", typically on the drivers door, in the console or in the glove box. The list of 3-character option codes should include "WS6".
      I figured it had to be that easy... thanks!!
      Dave M
      Dave M
        As Fred says, the best way is to look for the "WS6" option code on the build sheet or the window sticker (the '97 WS6 was modified by SLP; '98 and later WS6s by ASC in Canada). If the car has no window sticker, you can order one using the VIN. Might cost you a few bucks, but it saves you from being defrauded.
        A quick visual clue -- one that is not easily "cloned" -- is that all WS6 Firebirds (TAs or Formulas) have 17" wheels. Non-WS6 Firebirds (Formulas or TAs, included) have 16" wheels.
        R.i.K.
        '98 WS6 TA (white, of course!), Hurst Billet/Plus shifter, BBK intake manifold, McGard “blue-ring” lug nuts (12x1.5), PowerSlot brake rotors, Hawk brake pads, Stainless steel braided brake lines, Pontiac arrow, Hotchkis strut tower brace, MBA MAF ends, Reflective Concepts lettering, MTI carbon-fiber look airbox lid . . . and one greying, somewhat eccentric owner.
          Unless its a Vert the 97s verts came with no badges and 16" wheels but still have the WS6 rpo code........
          1997 Trans AM WS6 vert
          1 of 463
          LT4 knock module
          strut tower brace
          SLP fan switch
          160* t/stat
          Pictures Here
            Yup. BadWS6 is correct.
            R.i.K.
