i have an 82 z28 with the stock 4 speed t-10. My input shaft bearing blew out causing the input sleeve to die.
I plan on rebuilding it or swapping it out for a dif one, I have a few questions though.
1. would a 5 speed from an 83 z28 work? what all would the swap entail?
2. where is a good place to get parts for the t-10? i need new input shaft, bearing, sleeve and rear seal.
3. what do you guys think i should do? would it be cheaper to rebuild it or get a used one? are the 4 speed transmissions any good anyway? Im kind of on a budget so nothing too outrageous
thanks for any info or opinions,
seann
I plan on rebuilding it or swapping it out for a dif one, I have a few questions though.1. would a 5 speed from an 83 z28 work? what all would the swap entail?
seann
to go in on the 4 speed, thats why i was wondering if a clutch from a 4 speed would work on a 5 speed tranny, i know its a long shot but it seems like it would bolt up. the tranny has 138k
all the snap rings and washers and key ways have me a bit frustrated.
