Ok guy i know this has been on here may times but i forgot how to post a pic in my sig. can some one help out. thanks.
stupid question how to put pic in sig
99 T/A WS-6
88 IROC-Z, ZZ430 CRATE MOTOR, Flowmaster exhaust, MOSER 12-bolt with gears, and a few other mods.Tags: None
Your picture needs to be located on an Internet server, and you need the "URL" address. Embed that address inside the [img] code.
Example (the last [/ img] has an extra "space" init so it will appear on the screen):
[img]http://members.aol.com/Fredrick518/Photos/NewSig145.jpg[/ img]
The only difference is you have to delete the space between "/" and "img" in the final code. Then you get this:
[img]
[/img]
ok i got that part but for some reason the only thing that pops up is that little red x in the square.
99 T/A WS-6
I noticed that in the properties of your pic that your intended pic was located at f-bodyhideout.com. It is posssible that they do not allow hot-linking or maybe you could just have mispelled the URL.Originally posted by 99WS6TA
URL's can often be case sensitive as well. Hope this helps.
Bingo, I copied his URL before and loaded in my browser and it came right up.Originally posted by fastTA
thanks for everyones help i finally got it. I did have somethinging in the link wrong. thanks again.
99 T/A WS-6
